2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Pfadt Racing Poly Control Arm Bushing Kit
Old 08-19-2009, 03:18 PM
Jordan P.'s Avatar
If your Camaro still has the factory rubber bushings, you’re losing valuable control due to the flex of the soft rubber. Our Polyurethane kit will make your car respond to turns like never before. The package replaces all 18 control arm bushings. Front trailing arms use a spherical bearing for an ultimate engineered solution and low friction operation. With our poly bushings deflection is minimized and you’ll make the most of your alignment. We hard anodize the lightweight aluminum sleeves and include plenty of grease for an easy installation and proper long-term wear.
For more info including pricing please click on the picture!
* Poly bushings are graphite impregnated for long life and low friction
* Engineered with special grooves the poly bushings maintain lubricant on the bearing surface
* Custom aluminum sleeves were engineered for light weight, low friction operation
This is a complete system. It includes everything to replace all of the control arm bushings. Please feel free to call or email us anytime with questions or to find the correct package for you!
Kind regards,
Jordan P. is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
dbrockma
02-16-2015 02:56 PM
Jason Short
01-19-2015 06:34 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: [Suspension] Pfadt Racing Poly Control Arm Bushing Kit
