2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Pedders Supercar Coilover Warranty ALERT
Old 11-17-2010, 08:31 AM
Rob@WretchedMS's Avatar
Pedders Supercar coilovers ship in four individual boxes. The boxes are labeled clearly Left Front, Right Front, Left Rear and Right Rear. If the front units are installed incorrectly the ABS Wire and Brake Hose will preventing the technician for releasing the car with the front struts incorrectly installed. The wire and hose will not fit. In the Rear, the correct orientation has the reservoir / canister hoses faced to the differential. The REARS can be INCORRECTLY FIT. Installing the Rear Supercar coilovers with the hoses facing the wheels will result in leakage and failure. INSTALLATION ERROR is NOT covered by Pedders Warranty.
Any reports of hose leakage or failure will requirethe damaged / failed parts be shipped to Pedders USA for inspection. If there is any sign of physical damage to the hose or fittings warranty will be denied due to INSTALLATION ERROR.
1. The Supercar coilover boxes are clearly marked.
2. The Supercars do NOT fit into the rear arms with the hoses facing the wheels.
3. Hoses, fittings and coilovers damaged by INCORRECT installation VOID warranty coverage.
Correct Orientation – Hose toward the Differential.
INCORRECT INSTALLATION -- Pinch Point that occurs when INCORRECTLY installed.
Rob@WretchedMS is offline
WPHIG2
08-27-2015 06:37 AM
08-17-2015 09:50 AM
08-07-2015 08:52 AM
07-10-2015 02:23 PM
Quick Reply: [Suspension] Pedders Supercar Coilover Warranty ALERT
