2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Drag Racing Suspension Kits
Old 11-10-2009, 09:33 PM
DMS Motorsports's Avatar
Pedders has developed suspension kits for the drag racer in mind. Here are some of them:
PEDDERS CAMARO BASIC DRAG BUSHING PACKAGE
Merlin Store P/N is CAMAROBASICDRAG
10/5/2009 The Zeta II CAMARO Platform Is an excellent beginning suspension package that can be greatly improved with the magic that Pedders has to offer. Wheel hop is an issue for the G8. There will be 3 levels of Pedders Drag Packages to meet the needs of the occassional user to the hard core user. This is Level 1, our basic package
Part # Pedders Compnent Price
EP1201 CAMARO TOTAL REAR SUB FRAME BUSHING REPLACEMENT $449.03
EP1167HD REAR ZETA HD DIFFERENTIAL BUSHING KIT $138.36
EP6578 CAMARO Front Radius Rod STIFFENING SNUBBERS (new) $75.99
PDUSACAMFULL CAMARO REAR EXTENDED CAMBER, TOE ADJUSTERS, FRONT CASTER ECCENTRICS & CAMBER ADJUSTERS $210.00
PEDDERS CAMARO BASIC DRAG BUSHING PACKAGE PARTS TOTAL $873.38
Menu System Discount $223.39
Menu System Discount Adjusted Parts Total $649.99
PEDDERS CAMARO DRAG BUSHING KIT #2
Merlin Store P/N is CAMARODRAGKIT2
10/5/2009 This kit is designed to strengthen up the back end by replacing all the bushings in the rear and increase front positive caster. The strength of this drag package is to pass on torque, and seriously reduce wheel hop, and improve the 60 feet times. There will be 3 levels of Pedders Drag Packages to meet the needs of the occassional user to the hard core user. This is Level 2
EP7322 Camaro Rear Control arm - Upper inner rear. Possibly being updated $96.20
EP7264 Zeta rear lower control arm inner $96.20
EP7323 Zeta Camaro Rear Toe, and trailing arm links in and out. $96.20
PEDDERS CAMARO DRAG BUSHING KIT #2 PARTS TOTAL $1,450.58
Menu System Discount $350.59
Menu System Discount Adjusted Parts Total $1,099.99
10/5/2009 PEDDERS CAMARO EXTREME DRAG PACKAGE
Merlin Store P/N is CAMAROEXTDRAG
This package is for the CAMARO owner who uses his CAMARO primarily for Drag Racing. They will be able to use it on the street as well, but the handling through the twisties may be reduced There will be 3 levels of Pedders Drag Packages to meet the needs of the occassional user to the hard core user. This is Level 3, our extreme package
P/N PEDDERS PARTS DESCRIPTION PRICE
220032 "Camaro 2009 Front drop Coils & Ride Height with 20"" Wheels at 667mm
" $89.62
" $89.62
EP2112 Zeta Steering Rack Bush $26.25
EP6577 CAMARO Front Radius Rod Bushing $198.59
PEDDERS CAMARO EXTREME DRAG PACKAGE PARTS TOTAL $1,778.67
Menu System Discount $378.68
Menu System Discount Adjusted Parts Total $1,399.99
PEDDERS CAMARO EXTREME XA DRAG PACKAGE
Merlin Store P/N is CAMARO EXTXADRAG
10/5/2009 This package is for the CAMARO owner who uses his CAMARO primarily for Drag Racing. They will be able to use it on the street as well, but the handling through the twisties may be reduced There will be 4 levels of Pedders Drag Packages to meet the needs of the occassional user to the hard core user. This is Level 4,iT ADDS OUR ExTREME xa KIT to Level 3
160086 Camaro eXtreme Xa Multi Adjustable Coilover Kit By Pedders with 8kg/mm Front and 10kg/mm Rear Coil Rates $1,449.99
PEDDERS CAMARO EXTREME XA DRAG PACKAGE PARTS TOTAL $3,049.42
Menu System Discount $(649.43)
Menu System Discount Adjusted Parts Total $2,399.99
All of these kits are designed to assist you in traction and reducing wheel hop. If ytou have any questiions, just ask.
thanks,
mike
dms
DMS Motorsports is offline
Old 11-13-2009, 11:46 AM
Admin Emeritus
JasonD's Avatar
I am very surprised no one has jumped all over these. I'd also post these in the Drag Racing section here, those guys should eat it up!
JasonD is offline
Old 11-13-2009, 12:35 PM
2010_5thgen's Avatar
i would but i need to see what bushings i dont need to repace since i got some parts from BMR.
2010_5thgen is offline
Old 11-14-2009, 08:06 PM
Part of the challenge of knowledge is to determine what is needed or not needed. One of the things about ZETA II, this is the strongest structureal platforms on the market. Replacing links, adding structure and strut tower bracing and other bracing, is not needed. Looks cool, but is not needed. There is a big time reason the Camaro weighs more than the Mustang, You cannot get enough bracing in the Mustang. The Camaro needs no additional bracing or support, with the exception of overly soft bushings.
Now most will not understand poly bushings. Raw poly material ranges from $35 per gallon to over $425 per gallon. The poly used in the Pedders bushing material is in the mid $300 per gallon. You need this level of control to be able to have long term durability, noise abatement and control. Using a $35-$100 per gallon poly is seriously inferior and common place.
The structure of the rear links are perfectly adequate for very high hp. It is bushings that need to be looked at and upgraded to.
thanks
mike
dms
Old 11-16-2009, 07:17 AM
im still debating whther or not to do the bushings next spring or not. i want to. just dont know depending on cost and install cost.
Old 11-16-2009, 06:05 PM
If you come up with any pressing questions, we are here to assist you.
thanks
mike
dms
F'n1996Z28SS
08-23-2023 11:19 PM
Elcojoe
11-17-2014 10:27 PM
SLIMJIM
01-07-2003 11:06 AM
Wicked
07-29-2002 04:17 PM
Quick Reply: [Suspension] Drag Racing Suspension Kits
