[Tires] Different tread patterns
Thinking about running two different types of p zeros with new wheels to fit... What is the downside of having two different patterns? Or even types of wheels if I went with something else for wider rears?
Sent from my DROIDX using Tapatalk
Re: Different tread patterns
running differnet wheels(other than stock) is fine.only issue you may have,which i do, is if you run a wider wheel, you will notice the car pull a bit whenever you drive. with my wheels, i notice my car pulls and moves quite a bit from the grooves in the road. before with smaller tires, they just stayed in the grooves but now that their a bit wider, its hard for the car to find a natural spot to drive. so it walks around .
as far as tires...i dont know a problem with running different tires. i guess if thats what your set on, make sure the different tires are on front and back, not left and right. on my old trans am, i ran bfgoodrich comp ta on the read and different bfg's up front. never did much racing with them so i never noticed a difference.
06-19-2015 01:34 PM
Darth Xed
13
07-22-2002 12:45 PM
