2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] The definitive explanation of camaro suspension, issues, fixes, and upgrades and why
Old 10-02-2009, 07:41 PM
DMS Motorsports's Avatar
THE DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, FIXES, AND UPGRADES AND WHY
Spending the time and energy it has taken to have the expertise and understanding of the new Camaro has been that Pedders now has has been seriously fun, but exhausting at the same time. No one has the understanding of the amount of time it has taken to get to this point. But we did it. Every month, more and more Camaros are being sold at a very successful rate. So lots of nubees are coming into the suspension enhancement world an a daily basis. So to assist everyone, Pedders has labored hard to make a definitive explanation, about 14 pages, with a complete anaylsis of the Camaro suspension, and a detailed explanation as to why we do things the Pedders way. On a very interesting note, we have a link for you that shows why solid sway bars are on average, 15% stronger than hollow bars. This is a must read!
Here is the index:
Pedders 2010 Chevrolet Camaro Suspension Evaluation Pedders 2010 Chevrolet Camaro Suspension Evaluation - Page 2
Evaluation - Page 3 - Radius Bushes
Evaluation - Page 4 - Wheels and Tires
Evaluation- Page 5 - Sub-Frame Bushes
Evaluation - Page 6 - Driving the Camaro
Evaluation - Page 7 - Control Arm Bushes
Evaluation - Page 8 - Ride Height, Coils and Damping
Evaluation - Page 9 - Ride Height, Coils and Damping Continued
Evaluation - Page 10 - Alignment Bolts
Evaluation - Page 11 - Sway bars and Endlinks
Evaluation - Page 12 - Sway bars and Endlinks Continued
Evaluation - Page 13 - Sway Bars Endlinks Continued
Evaluation - Page 14 - Summary
Pedders now has all the p/ns for everything for the Camaro and have completed all the systems. We will have about 25 systems for you to choose from. Now this is a lot of systems to choose from. But once they are all up on our merlin store, I will make a post showing a progressive outline from system to system.
Now some will say this is too confusing to figure out. How I would respond to that question is simple. We have spent more time and energy, and money, on Camaro development, than any other vehicle in the USA. Understanding and becoming an expert on the handling of the Camaro is hard. There is no proper cookie cutter format for all set ups. This is why we have 3 different setups for the front radius rods, 2 setups for the rear differential mount bushings, 2 different options on the rear cradle bushings. Then 3 different options on sway bars. We did not just test one Camaro setup like others. We tested multiple Camaros from totally stock, to Xa Coil overs, to Xa coil overs with Street1 bushings, to our serious Track Systems. We also tested Camaros to find out what influences different sized tires have on the Camaro. We also seriously understand how hard everyone works in this market. We do not want to oversell you and give you parts, that you will not seriously see the benifit of it. So we offer different systems and will spend the time to assist you, finding the system that works perfectly for you driving habits, rear hp, tire size, and of coarse, budget. This is why we spent the energy to do this.
Here are the systems that are complete and will be in our merlin store within the next week or so. Note, some are already there.
2010 CAMARO PACKAGES
CAMARO Coil Drop Kit 1
Camaro Coil Performance Drop Kit 2
CAMARO Street 1
Camaro Serious Street 1 Packge
CAMARO SPORT PACKAGE
Camaro Touring DROP kit 1
Camaro Touring Perf. drop Kit II
CAMARO TOURING EXT. Xa kit
Camaro Street ii drop kit 1
Camaro Street ii Plus drop kit 1
Camaro Street II drop Kit II
Camaro Street ii Plus drop kit II
CAMARO STREET EXTREME XA
Street Extreme XA
StreetII Extreme XA PLUS
SERIOUS Track II Perf. Drop Kit II
SERIOUS Track II Drop Kit 1
Track II Drop Kit 1
CAMARO Extreme XA Track
CAMARO SERIOUS Extreme XA Track
G8 BASIC DRAG STRIP KIT
G8 Drag bushing Kit LEVEL 2
G8 Extreme Drag Package
G8 Extreme XA Drag Package
Our Pedders Camaro systems can be found at:
https://secure.merlinsoftware.com.au...AMARO+PACKAGES
If you have any questions, just ask
Mike
dms
DMS Motorsports is offline
Old 10-02-2009, 10:36 PM
Documentation showing solid bars stronger than hollow
Check out the section on sway bars. there is a link that can take you to a web site that has a lot of data on sway bars, hollow vs solid from Whiteline.
http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
The issue of solid vs hollow tubes is seriously addressed on this article. Weeding thru all the calculations, you will find the hollow tube is approx 15% less strength that solid, plus there is an issue the irregular bends and the strength vairations of the bars due to this. this issue is not present in solid bars, which is the reason Pedders uses solid bars.
mike
dms
Old 10-19-2009, 11:59 PM
We just added more data
mike
dms
Old 11-11-2009, 02:36 AM
Added more
Jazsun
12-29-2014 12:14 PM
CARiD
12-26-2014 04:20 AM
cmdeshon
12-12-2014 10:51 PM
Quick Reply: [Suspension] The definitive explanation of camaro suspension, issues, fixes, and upgrades and why
