2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Wheels] Confused on tire/wheel sizing
Old 06-09-2009, 08:52 PM
John_H's Avatar
I'm totally confused on how tires and wheels are sized.
Okay, the SS has 245/45ZR-20 on front and 275/40ZR-20 on the rear and the wheels are 20" X 8" on the front and 20" x 9" on the rear.
So, I don't know how you would size the tire with the wheel. I understand the diameter, but the width difference in the wheel and tire throws me off. How do you properly size the tire and wheel?
The reason I bring this up is because in the interview with Pete from Peddlers, he said we can have a 10" front tire and a 12" rear tire. I'm assuming he meant the the tire width, but what width should the wheel be? Also, does anyone know how sidewall height affects handling. I know the larger the sidewall, the better the ride is, but what is the optimum side wall height for handling?
John_H is offline
Old 06-10-2009, 02:24 AM
MetalDragon's Avatar
I believe he was referring to wheel width. As far as tire to wheel...I've been told that a good rule of thumb is to keep your tire width within plus or minus half an inch of your wheel width, but 275mm is about 10.8 inches on a 9 inch wheel, so who knows. If you follow this pattern...and you put a 12 inch wheel on, it would seem you could possibly put up to a 355/30/20 and have nearly identical diameter to stock. Too much or too little and the tire won't seat on the wheel properly, though and a 305/35/20 is almost exactly 12 inches wide with virtually the same diameter. Seems like there's a good bit of room to play with.
As far as optimum height for handling...technically, a strip of solid rubber wrapped around the wheel. It depends on what you want to do with it and how much of a trade off between performance and comfort. Generally speaking, less sidewall equals less "float" but rougher ride.
MetalDragon is offline
Nayr
03-03-2023 08:34 PM
93 RedBird
11-15-2015 08:24 AM
RX Speed Works
10-01-2015 10:19 PM
surreybrad
09-29-2015 09:00 PM
autoxr166
09-25-2015 04:21 PM
Quick Reply: [Wheels] Confused on tire/wheel sizing
