2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
2012 TPM no data
Old 10-24-2011, 02:52 AM
msa231v6's Avatar
2012 TPM no data
Hi, guys. I am not sure if this exact question has been asked after searching through some other threads, so I will try here.
I am working in a foreign country (China) receiving 2012 Camaros for import. I have a vehicle at the port that does not show any data for the TPMs - just dashes instead of a value. I am assuming they would have been learned correctly at the factory or else the vehicle would have failed the dynamic test systems and also would have an indicator light on the cockpit.
Any thoughts as to the next steps to take? It is not real simple to find a TPM tool and try to re-learn the TPMs.
Thanks for your time.
Michael
msa231v6 is offline
Old 10-24-2011, 09:52 PM
Admin Emeritus
JasonD's Avatar
Re: 2012 TPM no data
Tough call. I would check the sensors (not an easy task) and make sure they are still intact and in the right position.
JasonD is offline
Old 10-26-2011, 10:23 AM
Camaro2SSRS's Avatar
Michael
You can reset 2010-2011s without a tool. 2012s require a tool.
You can buy the tool here for $62:
https://gmspecialservicetools.spx.co...s.aspx?id=5677
Camaro2SSRS is offline
Novo
06-14-2016 02:58 AM
93 RedBird
11-15-2015 08:24 AM
leftclixLS3
09-17-2015 03:12 PM
techstar
08-11-2015 11:21 PM
colts0455
07-28-2015 11:28 PM
Quick Reply: 2012 TPM no data
