2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
2010 Camero 20" tires
Old 02-08-2013, 02:58 PM
genah's Avatar
Smile 2010 Camero 20" tires
I have a 2010 Camero with 20" times. Different sizes front/rear. Time for new ones and was looking for recommendation on brands. I live in SoCal so weather isn't an issue. Looking for performance and comfort.
genah is offline
Old 02-08-2013, 04:10 PM
bluz28's Avatar
Re: 2010 Camero 20" tires
BFGoodrich g-Force Sport COMP-2 $884 or Pirelli P Zero $1014 shipped from DTD, Or about the same from TireRack.
bluz28 is offline
Old 06-12-2013, 02:33 AM
mikefox's Avatar
Before going into any buying process for tyres just make a check list of the info available on the tires ribs as they are the ones that would disclose the considerations of quality in getting a new Tyre.
mikefox is offline
Old 06-12-2013, 08:38 AM
94Zee28's Avatar
BFG Sport Comp 2's are a great summer tire!
94Zee28 is offline
Old 06-18-2013, 08:07 PM
RickRay's Avatar
If your going for the most Tread Wear(more Life) then it has to have a larger UTOG:IE:
TREADWEAR: 220
TRACTION: AA
TEMPERATURE: A
Nitto Motivo = UTQG: 560 A A (All Season)
Nitto Invo = UTQG: 260 A A (Summer Only)
Gmax as-03 = UTQG: 480 A A (All Season)
Falken 452 = UTQG: 300 AA A (Summer Only)(Front Original Size Only)
Perilli P Zero = UTQG: 220 AA A (Summer Only)
Hankook Ventus V12 evo K110 = UTQG:280 AA A (Summer Only)
Goodyear Eagle GT = UTQG: 400 AA A (All Season)
Firestone Firehawk Wide Oval AS = UTQG: 400 A A (All Season)
Continental Extreme Contact DWS = UTQG: 540 A A (All Season)
BFGoodrich g-Force Sport COMP-2 = UTQG: 340 A A (Summer Only)
Cooper Zeon RS3-S = UTQG: 300 A A (Summer Only)
VREDESTEIN ULTRAC SESSANTA = UTQG: 280 AA A (Summer Only)
Here's a good site for description of tires:
Error - Discount Tire Direct
More Info: Uniform Tire Quality Grading (UTQG) Uniform Tire Quality Grading is a relative comparison system. Tires are graded by manufacturers in three areas: treadwear, traction and temperature.
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example, a tire graded 400 should have its useful tread last twice as long as a tire graded 200. Treadwear grades are only valid for comparisons within a manufacturer's product line.
Traction grades represent the tire's ability to stop on wet pavement as measured under controlled conditions on asphalt and concrete test surfaces. As of 1997, the traction grades from highest to lowest are "AA","A","B" and "C". The grades do not take into consideration the cornering or turning performance of a tire.
Temperature grades represent a tire's resistance to heat and its ability to dissipate heat when tested under controlled laboratory test conditions. The grades from highest to lowest are "A","B" and "C" . The grade "C" corresponds to the minimum performance required by federal safety standard.
WHAT IS TPMS?
Example for shipping Nitto Motivo to Quebec:
I just saw this for the threads on our tires:
CHECK TIRES THREAD DEPTH
GREEN = 8/32 or Greater
YELLOW = 7/32 to 4/32
RED = 3/32 or Less
RickRay is offline
Old 07-01-2013, 11:04 AM
Re: 2010 camaro 20" tires
Gee..... Mike. You indicate you are from Tustin, CA.... but your IP address is from Mumbai, India. Isn't this a bit odd?
Injuneer is offline
Old 07-12-2013, 04:42 PM
BowlingSS's Avatar
I just installed the Continental Extreme Contact DWS. I wanted the BFG but they stopped making the rear.
Good luck.
Bill
BowlingSS is offline
Boss002
07-24-2015 10:47 AM
Latronaxe
07-20-2015 12:00 PM
Z28amustangklr
07-18-2015 11:05 AM
Boss002
07-09-2015 03:33 PM
Slayer
07-04-2015 03:06 PM
Quick Reply: 2010 Camero 20" tires
