2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Wheels] 18" wheels on SS?
Old 05-07-2009, 01:25 PM
Malice 1's Avatar
18" wheels on SS?
I'm getting a 2010 SS with 20" midnight silver wheels.
Will I be able to fit a set of 18" C5 vette wheels on to the rear of the car?
My 4th gen uses 18" vette wheels with drag radials, and I want to know if I can swap them onto my 5th gen for drag strip outings.
Malice 1 is offline
Old 05-07-2009, 07:47 PM
Admin Emeritus
JasonD's Avatar
You may not be able to clear the brake calipers.
JasonD is offline
Old 05-07-2009, 08:16 PM
Rob V's Avatar
Front brakes are 14", rear are 14.4". You'll want to make sure you have enough clearance to fit the rims on, just like Jason noted.
Rob V is offline
Old 05-12-2009, 02:47 PM
JeremyNYR's Avatar
don't forget that the overall diameter of the tire is a good bit larger for the 5th gen too. The 20" rim on the fifth gen has as high of a sidewall on the tire as an 18" rim on a 3rd or 4th gen would.
JeremyNYR is offline
force10
08-10-2015 08:30 AM
30th Anniv Z28
08-01-2015 10:39 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
jasonduaine
06-04-2015 09:29 AM
Quick Reply: [Wheels] 18" wheels on SS?
