Tuning yourself out of a warranty?
Old 08-05-2010, 07:31 PM
DaveyC12's Avatar
I did the muffler delete and K@N Rampage C.A.I, and now I really want to do a dyno tune but don't want to affect the warranty. Does anyone know if tuning is allowed under the warranty? There is no way I will do one if it affects it. Thanks
2010 2SS/RS 6m
DaveyC12 is offline
Old 08-09-2010, 03:55 PM
SSCamaro99_3's Avatar
Technically, they can pull your warranty for any modification to the car. The mufflers probably wouldn't draw attention, the cold air likely will, and a dyno tune defiantely will.
SSCamaro99_3 is offline
Old 08-10-2010, 10:32 PM
Chevycobb's Avatar
Tuning will pretty much void any warranty no matter what breaks.
Most bolt-ons like catback and cai will rarely cause issues with warranty unless they are directly related to a claim.
Chevycobb is offline
Old 09-03-2010, 08:12 AM
FBodyBros's Avatar
They are correct. Basically, any little "modification" can void your warranty.
Personally, if you're looking to "fool" the stealerships these days. I would just purchase a second PCM, put it in before the tuning and get that pcm tuned. Then one day before you go to the dealership for your warranty work, just go ahead and switch them back.
One thing I did just think about though. Does anyone know where the actual odometer information stored? And would switching from PCM to PCM alter the actual milege from the displayed mileage? Something to ponder..
FBodyBros is offline
Old 09-03-2010, 08:33 AM
razor02097's Avatar
The instrument cluster stores the mileage.
razor02097 is offline
Old 09-03-2010, 09:22 AM
Super Moderator
JakeRobb's Avatar
The Magnuson-Moss Warranty Act requires that your warranty be upheld, even if you have modifications, unless the modification itself was directly related to the defect/failure that led to the warranty claim.
A tune is "directly related" to an awful lot of stuff on the car, so it would make your warranty invalid for a lot of things, but there are also a lot of things that the warranty would still cover (body, interior, wheels, brakes, steering, suspension, and more).
JakeRobb is offline
Old 01-06-2011, 08:37 PM
IrocSS85's Avatar
Re: Tuning yourself out of a warranty?
I work at a "stealership" and he's correct here. depends on what kind of problem your having. the whole warranty would not be voided. only whatever parts of it the modifications directly applied to. a "tune" is something the O.E.'s are starting to check for more and more with blown engines. while I havent tried it on the 5 gens, the 2 pcms idea would do the trick perfectly. but ofcourse now your spending alot more money to get a tune.
IrocSS85 is offline
Old 02-22-2011, 11:51 PM
JohnnyComeLatly's Avatar
I had a 97 Trans Am with tons of mods and the dealership had no problems with an SLP CAI, and other mods. At first they tried to negate the warranty for the EGR pointing at my JBA Longtube headers, but I pointed out GMPP sold them under warranty. They eventually did the warranty replacement.
I don't know if things have changed in the 6 year or so I've been out of this, but you used to be able to return to stock tunes with any tuner. So, return to stock, get warranty/smog check, and then go back to tune. Supposedly California was even going to start checking CHECKSUMs in the PCM to catch tunes, but I don't know if that ever passed (OBD3?)
JohnnyComeLatly is offline
RallyRed701/2
07-27-2015 02:55 PM
colts0455
07-24-2015 04:51 PM
Shookiez28
07-23-2015 01:55 PM
88IROC_Z
07-22-2015 11:38 PM
07-10-2015 02:23 PM
Quick Reply: Tuning yourself out of a warranty?
