Rev extreme catch can diy 2010 camaro ss
Old 09-16-2011, 11:48 PM
Mucker15's Avatar
REV EXTREME CATCH CAN DIY L99
I like the look and build quality of the Catch Can pretty cool and helpfull little mod. The item arrived quickly.
Ill post the Oil change results at my next oil change
TOOLS NEEDED
Ratchet
15 mm 11mm sockets
Razor blade
DIY NOTES:
I run my car with the Engine cover off, I will be getting a longer hose and tucking it away in the future to make it look a bit cleaner
Ill also be adding hose clamps as well
Having big mits isnt much of a help having a buddy with smaller hands helps
We tucked the drain clear hose neatly away
Mucker15 is offline
Old 09-17-2011, 03:28 PM
bluz28's Avatar
Re: Rev extreme catch can diy 2010 camaro ss
Nice, simple, and to the point, good write-up!
BTW did you check if there's room below the passengerside headlight to mount the can down there? That way if there is your catch-can will work even better, you can then (after drilling a small hole under the car) drain the can by reaching under the nose of the car, and it'll keep the engine bay less cluttered. I did this on my 99Z28 and it works great, but I don't know if you can do it on the 5th Gen Camaro SS.
bluz28 is offline
Old 09-18-2011, 03:59 PM
Mucker15's Avatar
Didnt even think of that
great suggestion Thanks
Mucker15 is offline
Old 09-20-2011, 09:54 PM
Admin Emeritus
JasonD's Avatar
Arrrgh...this reminds me to finish my writeup/review of the catch can I have yet to install.
Mike...check back in a few hundred miles and let us know how much oil is catches.
JasonD is offline
Old 09-20-2011, 10:17 PM
Mucker15's Avatar
After the next Oil change I plan to brother
If anyone buys a rev extreme kit in the future you might see a familar face in the directions ;0)
Mucker15 is offline
Collector Car
01-05-2015 10:58 AM
ModdedNerd
12-10-2014 08:42 PM
12-04-2014 11:56 AM
draven666
11-26-2014 07:16 PM
draven666
11-26-2014 07:10 PM
Quick Reply: Rev extreme catch can diy 2010 camaro ss
