More power
sufficient for what? was it sufficient for me? no. i had to replace it. is it sufficient for you? as far as good power, what power is good enough for you? are you looking to get 10,20, 50 rwhp? depends how much your looking for to tell you if its good power.
re-powerhog
I guess I'm asking if anyone has had good results with just a CAI with a 93 octane tune, 10-20 rwhp & rwtrq would be cost effective to me if the stock exhaust flow is sufficiant for this combination of Mods. Because if I put on headers and free flowing exhaust then I have to do cam and head work or I could do more damage then good by causeing reversion and even worst bastardization to the intake stroke right? Then I gotta do fuel delivery work and the cost never ends, I don't drive WOT to work every day or race kids in toyota's all I want is a freer breathing engine at a minimum cost. any good advise will be appreciated.
As for the rest of the mods you listed. They all will increase HP over an LS3 without those mods but I don't think they are worth the cost on a stock engine.
why head work
A man can put an open exhaust on an engine and obviously it will change the flow rate and back pressure which will change the scavaging effects of the exhaust causeing reversion at certian rpm's and that in effect causeing bastardization, you sound good but lost hp & trq. to correct it you must change the cam lift, duration and lobe seperation angle along with head porting in order for all this to work togather properly in an open exhaust system. I don't mean to sound argumentive, I have done some engine work in my past but I am not familiar with this LS3. If a CAI, predator program, axle back will not work with a positive effect then I will continue to search out what has worked for others. Semper fi.
i have done headers and catback on a few other ls motors and have never lost power. good luck with your journey my friend but i think the head cam work may not be needed as much as you say,if adding headers and a catback.
a little more power
Thank you for your replies, I am thinking more strongly about Headers with high flow cats, likely Borla all the way back to the tips, CAI, and predator sport tune, 1st to 4th skip shift eliminator, do you know how much loader this will be in the car as to will I have to crank up the volume on the radio? or can I still enjoy a fairly quite ride when not getting on it? again thank you.
F'n1996Z28SS
08-23-2023 11:19 PM
NewsBot
05-16-2015 03:40 PM
