LSA Crank PULLEY ISSUE HELP!!!
Old 11-20-2013, 05:49 PM
Diplomat's Avatar
2011 Camaro SS (AUTO) L99
ProCharger calls for crank pulley removal and installation of their pulley. I removed the old pulley with somewhat of easy once I rigged enough spacers to make the puller work. However the new pulley does not want to go on further than where I got it now. I've locked the trans to stop the crank from spinning but no luck. From what I can tell the back side of the pulley is about 1/8th inch from the crank case.
How close does it need to be? How do I know when its ON all the way?
HELP, probably a dumb question but never had to deal with a pulley as stubborn as this...
Diplomat is offline
Old 11-20-2013, 06:47 PM
Admin Emeritus
JasonD's Avatar
Re: LSA Crank PULLEY ISSUE HELP!!!
Tough on...wish I could help but you will likely have to call Procharger.
JasonD is offline
Old 11-20-2013, 06:53 PM
Diplomat's Avatar
Here is another question is the pulley supposed to be flush with the crank? What I mean by this...the hole where the crank bolt threads into (CRANK SHAFT) was it or does it sit flush with the pulley its self? I would think no...because the pulley slid pretty easily to this point and than it was a pain beyond. I would think I reached the end...?
I've never had to install one myself and no one knows on these new motors...
Diplomat is offline
Old 12-09-2013, 02:07 PM
Transam79h's Avatar
On ls1 engine you can just ram it with a 1/2 inch impact till it stops and you should be fine.
Transam79h is offline
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Rde Bandit
03-21-2015 10:17 PM
SpeedJunkee
01-27-2015 10:02 PM
Quick Reply: LSA Crank PULLEY ISSUE HELP!!!
