Lets get real about the weight of the Camaro
Old 08-22-2008, 05:34 PM
  #211
boxerperson's Avatar
Originally Posted by Ron78Z&01SS
Not too sure about that.
Depending on trim levels and tranmissions, all that seperates the V8 from the V6 is 144-163lbs for the auto and 80-119 for the manual. Considering that you'd probably want the turbo'd V6 to have the upgraded brakes and (probably) bigger sway bars, there really wouldn't be that much of a weight advantage. Hell, you could make up the weight difference by having less gas in the tank or going on a diet.
I'm not turbo "smart", so forgive me, but how easy would it be to get 122hp & 135lbs tq out of the V6 to match the LS3?
And then there might be an issue with reliability of the V6 transmissions holding up to LS3 power levels.
Sorry, but I just don't see it.
Again, I'd like to direct you to the Australian Ford Falcon, which is built on the platform that competes directly with the one Camaro is based on. The V-8 version of that one handles significantly worse than the Turbo-6, because it's much more nose heavy, and it weighs about 120lbs less overall. The V-8 has a couple horsepower (seriously...like..a couple.) over the 6, but acceleration is inferior in the 8, because the 6 actually has a much better torque curve.
And bumping a 300hp DI V-6 to 400hp would be VERY easy. It's done all the time, reliably. I imagine they'd use a destroked/bored version of the engine to get some extra strength, and easily attain that power figure.
And I think a lot of people would buy that. Over in australia, where they have almost the exact same taste in vehicles as us (they love V-8's and full size cars), the Turbo-6 Falcon is outselling the V-8 by a large margin.
boxerperson is offline
Old 08-22-2008, 06:15 PM
  #212
teal98's Avatar
Yeah, but that 5.4 in the Aussie Falcon is a lousy starting point for a high performance engine. It probably outweighs the LS3 by 120 pounds. It's basically just a long stroke version of the 4.6, which is itself larger than the LS3.
Ford Australia did the best they could with what they started with.
teal98 is offline
Old 08-31-2008, 08:29 PM
  #213
Geezer powered's Avatar
Did'nt have time nor did I want to read all 15 pages of this post. With that said I am disappointed in0 the new camaro in the fact that she is a poker. They could've made a lighter car and still met all the needs and requirements at the same price. Bottom line ford did on the mustang.
Geezer powered is offline
Old 08-31-2008, 08:42 PM
  #214
95birdible's Avatar
Porker? My 95 Bird Convert weighs 4200+ pounds not including driver and gas.
If the new vert can come in around the same weight as this one I will be happy.
95birdible is offline
Old 08-31-2008, 08:55 PM
  #215
Pruettfan's Avatar
Why don't you be so kind as to explain how they could have but chose not too. Your statement is not supported by any facts whatsoever.
Pruettfan is offline
Old 08-31-2008, 09:01 PM
  #216
MauriSSio's Avatar
how the heck did your 95 come in at 4200lbs! my FULL SIZE full framed 1968 Galaxie Convertible with a big block and C6/9in rear comes in around 4000lbs. and thats with all stock steel body/bumpers and full complete interior. Did your 95 have some kind of cast iron roll cage?
MauriSSio is offline
Old 08-31-2008, 09:25 PM
  #217
yellow_99_gt's Avatar
I think he's confusing the GVWR on the door tag for the curb weight. A 95 TA vert should be around 3600lbs.
yellow_99_gt is offline
Old 08-31-2008, 10:18 PM
  #218
TrickStang37's Avatar
+1
serious. maybe he has a convertible 95 sub-bird-ban.
TrickStang37 is offline
Old 09-01-2008, 03:43 PM
  #219
pruettfan my statement needs no facts other then the new camaro is a beast, it weighs what close to 400-500lbs more then a 4th gen and what 300-400 more then a mustang. I dont care how it couldve been done, but it can be. Bottom line is Ford did it ( and I dont like ford)
Old 09-01-2008, 09:35 PM
  #220
GTOJack's Avatar
The new Camaro is heavy, but if my 05 GTO is any indication, it should handle like a much lighter car.
GTOJack is offline
F'n1996Z28SS
08-23-2023 11:19 PM
NewsBot
12-21-2014 06:55 PM
AlaskaZ28
12-10-2014 02:37 PM
bossco
11-29-2014 10:18 AM
Quick Reply: Lets get real about the weight of the Camaro
