Sponsored by:
Sponsored by:
3.0 Camaro?
Old 10-30-2008, 01:48 PM
Eric77TA's Avatar
3.0 Camaro?
Now that stories are popping up about the new 3.0 HF v6 for the 2010 Buick LaCrosse and the new Equinox, what are the chances of this engine showing up as a new Camaro base (maybe LS only?) engine in the future?
They're saying 250 horsepower, but didn't give a torque figure. It seems possible to me that this might make a better "base" engine than the LNF 2.0 Turbo as chances are it has a better torque curve for a heavy car.
Eric77TA is offline
Old 10-30-2008, 02:19 PM
2010_5thgen's Avatar
that would be a good base engine. it would then be able to lower the cost of the base model.
2010_5thgen is offline
Old 10-30-2008, 02:22 PM
Z284ever's Avatar
Whether it would/would not make a good base engine is one thing, but why do you think it would be less expensive than the 3.6?
Z284ever is offline
Old 10-30-2008, 02:25 PM
DAKMOR's Avatar
NO.! Horrible! It would never have the same torque capabilities as the LTT. )?(
The car will still weigh in at 3800 lbs! Do you want worse gas mileage to save a few hundred dollars off the price of the car?
DAKMOR is offline
Old 10-30-2008, 02:45 PM
Dragoneye's Avatar
The car will still weigh in at 3800 lbs! Do you want worse gas mileage to save a few hundred dollars off the price of the car? ?
I agree that this shouldn't REPLACE the current base V6, but rather become a new, lower-level model. Orrr....thinking on the spot, here...what if this engine was put in the LS, and the 3.6L engine became only available in LT trims?
This engine would have better gas mileage than the LLT, weight be damned at this point -- it is what it is. Being that it's not turboed, a 250-horse 3.0L V6 with the same technology as the LLT, coupled with proper gearing and fuel mapping could potentially return 29, and even so far as 30mpg hwy at the deliberate loss of some performance. But 30mpg seems to be the magic number in consumers eyes - so if they could reach that number with this engine, then it would definitely be worth it, imo.
Dragoneye is offline
Old 10-30-2008, 02:53 PM
Z28Wilson's Avatar
No point in the Camaro unless it gets significantly better mileage. Otherwise it would just be a step backward for the car. Also, by the time this 3.0 debuts, the Mustang's base V6 should also be in 300 HP territory.
Z28Wilson is offline
Old 10-30-2008, 02:59 PM
skorpion317's Avatar
Let's see if this makes any sense.
The base Camaro LS comes with the 300 HP 3.6L DI V6. The car is pretty well-equipped with standard features for a base model car, and especially so starting at $22K.
Downgrading the Camaro LS to the 3.0L to save a few bucks (assuming the 3.0L costs less to produce than the 3.6L) would be pretty stupid. The difference in retail prices would be, at most, about $1000. Nevermind that you should never downgrade a vehicle - it should get better over time.
skorpion317 is offline
Old 10-30-2008, 03:00 PM
DAKMOR's Avatar
Originally Posted by Z28Wilson
No point in the Camaro unless it gets significantly better mileage. Otherwise it would just be a step backward for the car. Also, by the time this 3.0 debuts, the Mustang's base V8 should also be in 300 HP territory.
fixed.
And why go to a smaller displacement engine ? it's a v6, its a economical engine already, nothing short of expensive equipment and material will give it more fuel economy.
Which is the opposite ofr the V8 argument.
DAKMOR is offline
Old 10-30-2008, 03:28 PM
Z28Wilson's Avatar
fixed.
Why? Camaro's base V6 has upped the ante. The next Mustang will adjust accordingly.
Old 10-30-2008, 04:46 PM
Eric77TA's Avatar
If the potential 3.0 doesn't get better mileage than the 3.6, then why bother with even creating a 3.0 verison? Just put the 3.6 in everything.
Judging by the fact that they are putting the 3.0 in the Equinox, and likely making it the base engine in the Cadillac SRX (according to what GMI are reporting) I'd assume it gets better mileage than the 3.6 in vehicles of equal weight.
I'll be curious to see what the torque figures are.
I wasn't figuring on this engine replacing the 3.6, but as a possible mileage leader - remember that even though gas prices are falling (for now) there are still upcoming CAFE increases to be met.
If it were to show up, I'd expect it to be the standard engine on LS and nothing else. They could keep the 3.6 standard on LT and perhaps optional on LS.
Eric77TA is offline
Old 10-30-2008, 05:01 PM
HAZ-Matt's Avatar
Maybe if it was a turbo 3.0L more people would want it in the Camaro
But I agree it doesn't make sense to have another V6 that will probably not save much money (or actually increase production costs) and probably won't affect fuel economy much.
HAZ-Matt is offline
Old 10-30-2008, 06:14 PM
Eric77TA's Avatar
How does another V6 increase production costs if it's in another car line?
Why create a 3.0, which costs money, for the new Equinox and SRX when the 3.6 already exists? The 3.6 is a gas hog in the Vue, so I'm guessing they're figuring on some MPG savings in those vehicles.
Then why was the turbo 4 being examined? Last I heard, it was dismissed because the car was too heavy, but a V6 could eliminate some of the problems if there was enough torque.
There have been lots of discussions on here about smaller displacement V6s and 4s over the last couple of years.
Now that the car is here and gas is under $2.00 a gallon (which someone will probably argue it's not, even though it is here right now) again, I guess no one cares. But as those CAFE standards creep up, a couple of MPGs is going to be more significant to those numbers than you might think.
Doesn't really matter. I wasn't saying I was for it or against it, but if they were looking at 4 cylinders a while back, you don't think there's any concern about the car's fuel economy in the long run? It's decent, but not stellar.
Eric77TA is offline
Old 10-31-2008, 07:32 AM
wow! chill out bro. someone needs to get laid.
all i said was it would make it cheaper for a base model. and as far as getting better with time doesnt have anything to do with it. theres alot of mpg requirements now and as far as i would be concerned if there were a 4 cylinder turbo like they were thinking, i think that would be a down grade.
i was just making a point it would be cheaper for someone looking for a more fuel efficient less powerful camaro. i wouldnt buy it but maybe someone would. and 1,000 dollars less...i dont think so. maybe if you could somehow mate it up to the 3.6 tranny and it could use some of the components.
but damn settle down.
Old 10-31-2008, 10:29 AM
You're taking it more seriously than you need to. I'm not attacking you in any way, just pointing out that it doesn't make sense to downgrade a vehicle to save a relatively small amount of money.
Old 10-31-2008, 10:44 AM
JeremyNYR's Avatar
agreed... telling someone "they need to get laid" because you misinterpereted their mood at the time of posting is unneccesary. I didn't get the impression that Skorpion was getting bent out of shape at all. It really doesn't make much financial sense to add a 3rd engine to the Camaro lineup (or replace an existing engine) unless it truely increases sales to do so.
JeremyNYR is offline
Quick Reply: 3.0 Camaro?
