[Interior] Help with Interior Lighting problem
Old 08-05-2010, 05:09 PM
Captain X's Avatar
I just took delivery of my 2011 2SS/RS. LOVE the car... except the interior lighting. Can't believe that there is only one white interior light! No
footwell lights, not really even a dome light, only the roof light over the shifter.
AND, what's up with the blue accent lighting? In the pictures it wraps around the cockpit. On my car, it is only on the doors. Is this correct or does my car have a blown fuse or something... Is your car like this?
Captain X is offline
Old 08-05-2010, 07:40 PM
Rob V's Avatar
No ambient lighting across the dash. Only on the door panels. Always has been that way since the the first delivery of the 2010s.
Rob V is offline
Old 08-05-2010, 10:27 PM
Captain X's Avatar
That's strange then, and maybe false advertising. I've got a picture of the interior with the blue line of the doors continuing across the dash to the other door. Can't see why they would lie about that when everything else is first rate.
Old 08-06-2010, 11:44 AM
Camaro X's Avatar
From one "X" to another.
They had originally intended on installing ambient lighting. For one reason or another they did not. There have been serveral people that have added ambient lighting to the dash. I used flexible neon light tubing, but there are other options as well. You should be able to search "Ambient Lighting" and find a DIY if you want to install it yourself. On the 2010's there is a connector in the harness behind the tach that was going to be used for the lighting, that made the install easier to power. I don't know if they still have the plug in the harness of the 2011's.
Camaro X is offline
Old 08-06-2010, 12:12 PM
jcamere94z28's Avatar
from my understanding there is a loose plug somewhere that they had planned on adding it to the dash. Some people have actually done the conversion to have a full ambient light like the concept...
You can see some samples of what i am talking about here:
http://www.camarostyleguide.com/SC-interior.htm
jcamere94z28 is offline
Old 08-10-2010, 10:23 PM
2SSRS's Avatar
The connectors on the harness was removed from late year 2010 cars and is not on the 2011 cars at all, And the OEM way to do it is no longer available, The Tyco parts are now not made any more.
Not some a lot do have it.
2SSRS is offline
RUENUF
05-25-2016 08:10 PM
01-23-2015 01:13 PM
Collector Car
01-05-2015 10:58 AM
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
Quick Reply: [Interior] Help with Interior Lighting problem
