Clear side markers installed
Found some clear side markers for the Camaro on ebay and ordered them. It's a pretty easy install, I just removed the 3 screws at the front of the wheel well liner to get access to the side marker. There is tab that you push in so the side marker pops out. Then just install the new bulb and insert the new side marker.
Here are some videos to compare stock vs. clear
Light off
http://www.youtube.com/watch?v=Ru_-l1WfLg8
Light on
http://www.youtube.com/watch?v=rNQPPnYAB8w
Light off
Light on
i took my stock side markers lights out to paint them and i didnt take any screws out. all i did was used a long flat head screw driver, and stuck it in the opening next to the inner fender and the bumper. that little hole is there for this reason. and all you do is press the tab and the marker pops out and you slide it out.
I just used a flat head screw driver to push on the tab which causes the side marker to start to pop out.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
