[Electronics/Car Audio] Adding Sub Woofer and amp only
Old 06-22-2010, 03:18 PM
brn2fly's Avatar
I just bought my 2010 Camaro last week. It is a 1SS with stock sound system. It sounds good but I would like to add a little more base to it. I have an Infinity dual voice coil sub and Kenwood amp which uses RCA jacks. Does the camaro come prewired to add an amp and sub in the trunk? (I saw the mtx sub box on the accesary page)
brn2fly is offline
Old 06-22-2010, 05:25 PM
badbandit12's Avatar
I too am going to add a couple of tens and a amp. I have not studied the system yet i have the Boston acustics system, so not sure about a stock amp or what adaptor is needed. when I get time to check in I will post some info. I am going to do a fiberglass box on the side and paint it to match the car.
badbandit12 is offline
Old 07-03-2010, 01:36 AM
Lowridah98's Avatar
am also very interested in knowing any results. I plan on having 2 10's installed in my trunk with amp and Cap but want to know that when its done the shop will be able to properly connect everything to the factory radio.
Lowridah98 is offline
Old 07-07-2010, 10:33 AM
shock6906's Avatar
I don't think I've ever seen a car that had RCA outs on the factory head unit. You can use a line-out converter to give you a set of RCA's, though. It ties into the speaker wires (usually the rears) to create the signal.
shock6906 is offline
Old 07-08-2010, 09:52 PM
I have found a company that makes a plug and play for the 2010 camaro with Boston in it I am going to order a few of them. I going to start my box soon.
Old 07-09-2010, 07:15 PM
Lowridah98's Avatar
I jus want something like 2 10" Alpine type R's or something with about 500W pwr ... nothing too overpowering. I just dont like the pricing they have for the plug and play sub sytem you can get from GM.
Old 07-11-2010, 09:37 AM
If you have any system with a factory amp you have to tie into the wiring before the amp. I haven't seen anyone in this thread say the factory head unit had RCA plug? There's company that do make plugs to tie into the head unit for that.
Old 07-14-2010, 10:27 AM
TBSPW's Avatar
the line out converter that shock mentioned isnt that bad...not the best but i used it in my impala for quite sometime and it did sound very good...but if youre a huge bass nut i bet you can tell the difference...mine still sounded better than a few of my friends systems with aftermarket head units
TBSPW is offline
Old 08-20-2010, 07:22 PM
Richy_Rich's Avatar
Save some time, busted knuckles and stress with a T harness...
Moderator may want to sticky this link...
http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622
Not to metion some nice custom sub mounts (bottom of that page).
Would also suggest a DE (digital amp) Bazooka rated at 250watts...
http://www.sonicelectronix.com/item_...BTA10250D.html
Richy_Rich is offline
Old 08-26-2010, 04:03 AM
HumbleBlue's Avatar
Many of the solutions I have seen out there for adding in an aftermarket amp or sub have been for the Boston Acoustic system. I have a 1SS with the stock sound system, is the wiring or amp in my car drastically different from that of the Boston systems? If so then how do the two differ?
Thanks for the help.
HumbleBlue is offline
Old 08-31-2010, 09:15 AM
Richy_Rich's Avatar
Better T harness link...
Old 10-11-2010, 04:15 PM
alfieboy's Avatar
harness
Contact Steve @ subthump ...originator of the 2010 plug n play rca harness.. and pricing better.. screw the copy cat guy on ebay who charges double .. and is already in copyright infringement
Rick
alfieboy is offline
Old 12-23-2010, 03:51 PM
roblord's Avatar
Re: Adding Sub Woofer and amp only
1ss, simply connect amp to battery under spare air pump(no tire), use speaker level to line level converter, available anywhere (Walmart has a 4 channel for $20). Switch the selector to line out, connect rca's to amp and run your remote turn on from behind deck.
roblord is offline
Old 12-24-2010, 02:33 PM
roblord's Avatar
If you don't feel like pulling the deck out, just run your remote wire to black plug, blue wire. Above pedals!
roblord is offline
Old 02-06-2011, 01:16 AM
5thgencrazy68's Avatar
http://subthump.com/Chevrolet-GMC-Su...Enclosure.html
5thgencrazy68 is offline
Quick Reply: [Electronics/Car Audio] Adding Sub Woofer and amp only
