3rd brake lite wiring
I want to add a flasher to the third brake lite on my 2010 camaro 1ss/rs- can anyone tell me where is the wiring to the 3rd brake lite unit hidden and is it a single wire or a two wire system? I do not want to tear out the rear package tray or the interior if I can help it. Thanks for any information. KL
Re: 3rd brake lite wiring
The wiring harness connection is behind the right panel under the small side window. Lower the seat, grab that plastic panel and pull evenly. When you get in there, the connection plugs into the main harness at the right rear as you face the panel. You will see the third lite wiring go off to under the rear window shelf.
07-04-2005 05:00 PM
